Media's conflict when copying entries
HADA
Post by HADA » 26 Oct 2021, 13:46
Aimeos : 2021.07.4
Laravel 8
Hello Aimeos, thank you again for your efforts.
I found a weird behaviour when copying a entire entry from the admin panel :
For products for example, let's say a product A has a media "Media1.jpg", when duplactating the Product A to create a new Product (let's call it "Product B"), if i change the product B media before saving (to have "Media2.jpg" for example), and then save, Media1.jpg is deleted from the filesystem. That always leads to loose images on the initial product (whose entries should be copied )
I guess it has something to do with and unhandled case in the media controller here :
if( $path && $fs->has( $path ) ) {
			$fs->rm( $path );
When duplacting a product, and before saving it, the path still refers to the initial product media.
Thank you in advance
Re: Media's conflict when copying entries
Post by aimeos » 27 Oct 2021, 10:57
Thank you for your issue report. The problem is now fixed in aimeos/ai-admin-jqadm:2021.10.x-dev.
You need to update to 2021.10 LTS because 2021.07.x isn't supported any more.
HADA
Post by HADA » 29 Oct 2021, 08:20
aimeos wrote: 27 Oct 2021, 10:57 Thank you for your issue report. The problem is now fixed in aimeos/ai-admin-jqadm:2021.10.x-dev.
Noted, thank you !
