Multiple identical attributes for select products in frontend
I have select products with attributes color and size. They appear correctly in the frontend.
But when I choose the tab for the attributes it shows me nothing with some variants and for other variants it shows me 4 times the same color and one times the size and with other variants 3 times the color and 2 times the size etc.
System is Linux, Typo3 10.4.21, PHP 7.3.30, aimeos 21.10.1
Re: Multiple identical attributes for select products in frontend
A setup with the demo data doesn't show the described behavior. How did you set up your products? Can you post a few screenshots?
I set up the selection products exactly as described in the Youtube video. Is it possible to hide the attribute tab?
- Eigenschaften.png (37.12 KiB) Viewed 7261 times
- Selection.png (36.38 KiB) Viewed 7261 times
Can you please post screenshots from the backend that shows your selection/variant article attributes?
Here it is
- selection_3.png (190.14 KiB) Viewed 7252 times
- selection_2.png (129.11 KiB) Viewed 7252 times
- selection_1.png (50.61 KiB) Viewed 7252 times
Problem has been fixed in dev-master and 2021.10.x-dev branches of aimeos/ai-client-html package and will be part of the next release. You can get the latest changes in the meantime using:
composer req aimeos/ai-client-html:2021.10.x-devProfessional support and custom implementation are available at Aimeos.com
