Image background becomes black
MikaelNazarenko
Expert
Post by MikaelNazarenko » 30 Nov 2021, 11:45
Hi community!
I faced with strange problem. When I attach image to product and save product - png image with transparent background gets black background... We use last aimeos version. It happens on remote server. On my local dev ubuntu machine it works fine.
What could be the problem.. ? Does it depend on some php-extensions or ?
I have attached image. You can see, before upload it was with transparent background and after it got black.
Thanks for any ideas !
MikaelNazarenko
Expert
Re: Image background becomes black
Post by MikaelNazarenko » 30 Nov 2021, 11:50
I just tried to add to the config/shop.php
        'controller' => [
            'common' => [
                'media' => [
                    'standard' => [
                        'options' => [
                            'image' => [
                                'name' => 'Imagick',
                                'quality' => 75,
Does not help ((
MikaelNazarenko
Expert
Post by MikaelNazarenko » 30 Nov 2021, 12:58
I think because of imagick not installed )
Post by aimeos » 01 Dec 2021, 11:50
Yes, that's most likely the case. Otherwise, Imagick would have been automatically used.
