Update interval value using json api
NouhailaBertal
Post by NouhailaBertal » 16 Dec 2021, 10:50
Hi I want to update interval value on basket page using json api and jquery :
2021-12-16 (2).png (44.16 KiB) Viewed 1944 times
Customer will choose the new interval value then click on update.
I have followed the documentation but the interval still the same (no changed )
2021-12-16 (5)_LI.jpg (105.78 KiB) Viewed 1944 times
Re: Update interval value using json api
Post by aimeos » 16 Dec 2021, 17:11
You use the "basket" resource and the "GET" method for your request but you need the "PATCH" method for the "basket/product" resource:
https://aimeos.org/docs/latest/frontend ... t-products
