Saving Product Variants Error in Admin Panel
kappa_dev
Post by kappa_dev » 20 Dec 2021, 13:30
After creating some attribute types and pick them in attributes and finally add those attributes to product, it couldn't be saved on the admin panel and generally saving this product only returning the error of "fail to save".
the product type was "selection" of course.
Then in "product_list" table i noticed a new record of this product with the "key = attribute|variant|11". manually deleted this records and seems everything started working again with this product.
we may can't re-produce the error, do u have any thoughts that what happened or the origin of this issue ?
OS: Mac
Aimeos Ver: dev-master
Laravel: v8.75
PHP: v8.0.12
DB: MySQL
Tnx.
Kappa Dev.
Re: Saving Product Variants Error in Admin Panel
Post by aimeos » 21 Dec 2021, 15:38
Can you please have a look into the Log panel of the admin backend?
There you will find detailed information about the error including a stack trace.
Then, please post the relavant error details.
