Subscription Cronjob dont Work
i have activated the subscription-function for a product, i set the interval time to one hour.
I made a test buying. the subscription-status is enabled and Reason is None.
I dont know why it does not work.
the documentation says i have to work with cronjobs, but i dont find any scheduler which is for subscription.
the system is TYPO3 V10 and Aimeos 21.4.1 , we want to upgrade next year.
Thanks in advance
Thanks in advance
Re: Subscription Cronjob dont Work
This is OK.hansklatt wrote: 22 Dec 2021, 09:33 i have activated the subscription-function for a product, i set the interval time to one hour.
Use the Aimeos advanced scheduler and select the "Subscription process begin", "Subscription process renew" and "Subscription process end" jobs to be executed once a day.hansklatt wrote: 22 Dec 2021, 09:33 the documentation says i have to work with cronjobs, but i dont find any scheduler which is for subscription.
