Integrate with multi-vendor marketplaces
godadada@yahoo.com
Post by godadada@yahoo.com » 14 Jan 2022, 10:03
Hey,
I plan to purchase 'multi-vendor marketplaces' after fixing a few issues i have now. How hard is it to integrate an existing Aimeos app with it?
Regards
nos3
Re: Integrate with multi-vendor marketplaces
Post by nos3 » 15 Jan 2022, 09:58
No, it's pretty easy because the marketplace extension adds the possibility to create trees of sites and therefore, mainly extends the admin backend and the Aimeos core. The templates and themes are not affected.
ottowiner
Post by ottowiner » 02 Nov 2022, 16:04
hello. how can i activate the multivendor template??. thanks
Post by aimeos » 03 Nov 2022, 10:28
You need to buy the marketplace extension from the Aimeos company:
https://aimeos.com/extensions#c436
