basket plugin - rebate product
stiller
Post by stiller » 16 Jan 2022, 17:04
hi there
I do understand how to add a specified rebate product to the basket if a certain condition is met.
see e.g. viewtopic.php?f=15&t=1721&p=7091&hilit= ... ugin#p7091
but how to remove the product again if the conditions are not met anymore after basket changes.
there are standard solutions for coupon provider fixed and percent.rebate but not for basket plugins.
has someone already developed a solution for this in the past ?
would be great to get some hints
Re: basket plugin - rebate product
Post by aimeos » 18 Jan 2022, 08:51
The coupon products are automatically removed if the conditions aren't met any more:
- https://github.com/aimeos/aimeos-core/b ... on.php#L91
- https://github.com/aimeos/aimeos-core/b ... #L441-L462
