aimeos:setup error
IvanIgniter
aimeos:setup error
Post by IvanIgniter » 19 Jan 2022, 08:40
I am using laravel 6.x, PHP 7.4, mysql 8, Docker desktop/Ubuntu and the Aimeos 2021
I have successfully installed and updated:
composer require aimeos/aimeos-core:~2021.10.4
composer require aimeos/aimeos-laravel:~2021.10.2
composer update
php artisan vendor:publish --all
php artisan migrate:fresh --seed
php artisan passport:install --force
But in this part I am having a trouble. Can you please help me how to solve this?
MicrosoftTeams-image (6).png (113.47 KiB) Viewed 4057 times
Re: aimeos:setup error
Post by aimeos » 20 Jan 2022, 14:18
This is strange and should not happen because there's a pre-dependency to TablesCreateMShop setup task which creates the mshop_index_text table:
https://github.com/aimeos/aimeos-core/b ... rm.php#L24
Can you check what exactly happened and if the TablesCreateMShop setup task has run before?
IvanIgniter
Post by IvanIgniter » 21 Jan 2022, 05:07
Yeah it just happen recently and I have no issue way back before. My fellow dev has no issue in this part.
What do u mean TablesCreateMShop setup task?
What should I do?
Post by aimeos » 22 Jan 2022, 11:04
Please have a look which setup tasks are executed in which order, especially if the TablesCreatePlatform setup task runs before the TablesCreateMShop one.
