Where to get Categories List from Databse
kartikbhat
Post by kartikbhat » 01 Feb 2022, 07:16
I need to display all the categories (specifically subcategories of HOME category) in one html page and need to create a hyperlink to each category, which redirects me to page where I can view products under that category; kindly let me know what flow that I need to follow to achieve this...
Laravel V : 8.4
Aimeos : 2021.10.*
PHP v: 7.3
Paltform : Windows 11
Re: Where to get Categories List from Databse
Post by aimeos » 02 Feb 2022, 09:59
You can either use the catalog/filter component in your page like done here:
- https://github.com/aimeos/aimeos-larave ... op.php#L30
- https://github.com/aimeos/aimeos-larave ... ade.php#L7
- https://github.com/aimeos/aimeos-larave ... de.php#L18
Another option is to use the Aimeos Catalog frontend controller class in an own Laravel controller to retrieve the categories:
$tree = \Aimeos\Controller\Frontend::create( app( 'aimeos.context' )->get(), 'catalog' )->getTree();
The available methods are described here:
https://github.com/aimeos/ai-controller ... /Iface.php
