How can I change the media type when importing csv ?
santfather
Post by santfather » 02 Feb 2022, 10:59
Laravel version: 8.80
Aimeos version: 2021.10
PHP version: 8.0.8
Win user
In the admin panel, I created a new media type for images. This is the media type I want to use for the generated component (widget). I made changes to the shop.php file. Added the necessary information to csv. The import went without errors, but the media type for the selected products did not change.
Re: How can I change the media type when importing csv ?
Post by aimeos » 02 Feb 2022, 17:02
Add a new column for media.type in your CSV file directly before or behind the column for the media paths:
https://aimeos.org/docs/latest/cronjobs ... ort/#media
santfather
Post by santfather » 03 Feb 2022, 14:05
aimeos wrote: 02 Feb 2022, 17:02 Add a new column for media.type in your CSV file directly before or behind the column for the media paths:
unfortunately it didn't help. maybe there is a possibility to add Media title in Media / Media properties via csv import?
Post by aimeos » 04 Feb 2022, 10:00
Importing media properties are not supported by the CSV importer.
Can you post your mapping and a snippet of your CSV file so we can check if there's something wrong?
