Stripe
agatqapp
Stripe
Post by agatqapp » 04 Feb 2022, 11:26
Hello sir
I want to display stripe card detail fields on checkout page
I added stripe form on checkout page payment-body-standard.php by stripe js
its display card detail form , on submit i create a token and set in input field name "paymenttoken"
and create a stripe.php class under aimeos\ai-payments\lib\custom\src\MShop\Service\Provider\Payment
here in process already a condition for paymenttoken field, which i set in form
if( !isset( $params['paymenttoken'] ) ) {
return $this->getPaymentForm( $order, $params );
on submit form its create token and submit in form but its redirect on same checkout page with error message
"tok_1KPPrkFr9ULUDfrYs5iUue2Y
Unknown service attributes"
Re: Stripe
Post by aimeos » 06 Feb 2022, 10:20
Can you show your complete code?
agatqapp
Re: Stripe
Post by agatqapp » 06 Feb 2022, 10:45
ok, attached payment-body-standard.php and stripe.php
Stripe.php.zip
(6.9 KiB) Downloaded 674 times
Re: Stripe
Post by aimeos » 08 Feb 2022, 11:00
Can you check here where the error occurs and post a stack trace?
https://github.com/aimeos/ai-client-htm ... #L341-L359
agatqapp
Re: Stripe
Post by agatqapp » 08 Feb 2022, 15:05
here generate error
catch( \Aimeos\Controller\Frontend\Exception $e )
			$error = array( $context->getI18n()->dt( 'controller/frontend', $e->getMessage() ) );
			$view->standardErrorList = array_merge( $view->get( 'standardErrorList', [] ), $error );
Re: Stripe
Post by aimeos » 08 Feb 2022, 17:09
Stack trace?
