No value for key "slider" found
Rathod Narendra
Post by Rathod Narendra » 10 Feb 2022, 10:24
Hello!
I can set up AIMEOS in localhost but I can not run the project. It says "No value for key 'slider' found" but I have the slider data on the database. - https://prnt.sc/26ss40u
When I update the composer, I'll get an error. - https://prnt.sc/26sq7g0
Can you please help me with this?
PHP- 7.3.27
Composer- 2.2.5 2022-01-21 17:25:52
Laravel Framework- 6.20.44
NPM- 8.1.0
Node- v17.0.1
Re: No value for key "slider" found
Post by aimeos » 11 Feb 2022, 14:18
Rathod Narendra wrote: 10 Feb 2022, 10:24 I can set up AIMEOS in localhost but I can not run the project. It says "No value for key 'slider' found" but I have the slider data on the database. - https://prnt.sc/26ss40u
In your "autoship" extension, one template accesses "$this->slider" which isn't a view variable you've assigned in JQAdm class.
Rathod Narendra wrote: 10 Feb 2022, 10:24 When I update the composer, I'll get an error. - https://prnt.sc/26sq7g0
Never (!) copy all files from Aimeos core or extensions to your own extension!
Only store your own classes and templates there!
