Change single product route parametr
Arm
Post by Arm » 11 Feb 2022, 13:31
Hi.
I have such a problem.
I want to change single product route system.
For example current route is www.test.com/en/Blue-car, but I want it to be www.test.com/en/blue-car.
But in this situation 'Blue-car' is product URL segment field value.
That is: my URL segment be 'Blue-car', but in browser head be www.test.com/en/blue-car.
Thank you.
Re: Change single product route parametr
Post by aimeos » 14 Feb 2022, 08:03
Change the URL segment in the product detail view to "blue-car" instead (use "..." to show the additional fields). This is the easisest way to change the value in the URL.
Arm
Post by Arm » 14 Feb 2022, 08:54
In Product details URL from Admin Panel the blue car is written correctly (www.test.com/en/blue-car), but from outside, in URL it shows with capital letter (www.test.com/en/Blue-car)
Post by aimeos » 15 Feb 2022, 09:35
Did you clear the cache?
