Jsonapi Typo3 Endpoint/ Search Products
mefailing
Post by mefailing » 15 Feb 2022, 14:18
we use an Aimeos store in Typo3. We would like to add a search function to the website. How is this possible?
We wanted to search for products via jsonapi, however we can not find the correct endpoint/ url path. "/jsonapi" returns 404 not found. What is the correct address for Typo 3?
Thanks a lot for the help.
(Version 18.10/ Windows)
Re: Jsonapi Typo3 Endpoint/ Search Products
Post by aimeos » 16 Feb 2022, 13:45
The JSON API endpoint depends on the TYPO3 URL of the "jsonapi" page in the page tree. If it's "Shop > jsonapi", then your URL should be "/shop/jsonapi".
Please note that Aimeos 18.10 is gets bugfixes and security fixes within the ELTS package:
https://aimeos.com/support#c428
The other option is to upgrade to 21.10 LTS to be on the save side.
mefailing
Post by mefailing » 23 Feb 2022, 10:06
Thank you very much for the quick reply, that helped a lot.
The URL we got back via OPTIONS works fine.
However, as soon as a filter is added, we get a "404 Page not found" error.
We have tried a few different filters, but always get a 404 error.
Url without Filter:
/shop/json-api?ai[action]=options&ai[controller]=Jsonapi&ai[resource]=product&cHash=1487183df0c22c27b95b6a6ed721e574
URl with Filter:
/shop/json-api?ai[action]=options&ai[controller]=Jsonapi&ai[resource]=product&cHash=1487183df0c22c27b95b6a6ed721e574&ai[filter][>][product.type]=select
var url = '/shop/json-api'; // Base URL from config
var promise = $.ajax( url, {
    method: "OPTIONS",
    dataType: "json"
promise.done( function( options ) {
    var args = {
    'filter': {
      '>': {'product.type': 'select'}
  var params = {};
  if(options.meta.prefix) { // returned from OPTIONS call
      params[options.meta.prefix] = args;
  } else {
      params = args;
  $.ajax({
      method: "GET",
      dataType: "json",
      url: options.meta.resources['product'], // returned from OPTIONS call
      data: params
  }).done( function( result ) {
      console.log( result.data );
Post by aimeos » 24 Feb 2022, 07:22
Maybe the cHash is the problem. Does it work if you remove it from the URL?
