Short name for the language
santfather
Post by santfather » 17 Feb 2022, 10:55
Laravel version: 8.80
Aimeos version: 2021.10
PHP version: 8.0.8
How can I reduce the length of the language name. For example, En instead of English?
Re: Short name for the language
Post by aimeos » 18 Feb 2022, 08:17
Overwrite the language template of the locale/select component, remove
$this->translate()
and only use the language code, e.g. "EN".
santfather
Post by santfather » 18 Feb 2022, 08:58
Thanks. That helped
