Mandatory field space only input causes error
IvanIgniter
Post by IvanIgniter » 22 Feb 2022, 11:08
I am using laravel 6.x, PHP 7.4, Docker desktop/Ubuntu and the Aimeos 2021 (aimeos-laravel: 2021.10.4 / aimeos-core: 2021.10.13)
We are having an issue in the product detail page mandatory field when inputting just a space only will cause error 500 after saving. How can we adjust the code so it won't accept just a space?
IvanIgniter
Re: Mandatory field space only input causes error
Post by IvanIgniter » 23 Feb 2022, 13:10
Any documentation how does aimeos filter each required field so we could enhanced each field filter needs?
Post by aimeos » 24 Feb 2022, 07:19
Currently, Aimeos only checks if the SKU isn't empty and for some invalid characters but not for white spaces:
- https://github.com/aimeos/aimeos-core/b ... d.php#L158
- https://github.com/aimeos/aimeos-core/b ... #L480-L491
Think, we should add spaces too.
IvanIgniter
Post by IvanIgniter » 28 Feb 2022, 08:06
Yeah that is my question how to avoid inputting a white space for a mandatory fields?
Is there any solutions?
Post by aimeos » 01 Mar 2022, 08:55
Only in dev-master. You can overwrite the JQAdm template for the product detail view and add a regex to the input field that forbids white spaces only:
https://developer.mozilla.org/en-US/doc ... es/pattern
