Homepage for eachsite
JanAlfred
Post by JanAlfred » 24 Feb 2022, 02:51
Hi, I'm new to Aimeos. I'd like to use multisite Aimeos. when I go to mymainsite.com it shows me the homepage perfectly. then I create a new site on the same domain mymainsite.com/vendor1. i tried to create a homepage for the vendor1 with its logo etc using the CMS provided but all i get is page not found and an empty page with only the header and footer (with main homepage logo). how do I create a homepage for each vendor that I create? should I use the CMS?
thanks
Jan
I'm using Laravel 6 , Aimeos 2021.x, PHP 7.4 and Windows 10.
Re: Homepage for eachsite
Post by aimeos » 24 Feb 2022, 07:31
To show a CMS page for each vendor, you have to add this route in your ./routes/web.php file:
// prefix: yourdomain.com/vendor1
Route::group(['prefix' => '{site}', 'middleware' => ['web']], function () {
    Route::match(['GET', 'POST'], '{path?}', '\Aimeos\Shop\Controller\PageController@indexAction')
        ->name('aimeos_page')->where( 'path', '.*' )->where( ['site' => '[a-z0-9\-]+'] );
Also have a look at the documentation: https://github.com/aimeos/ai-cms-grapesjs#laravel
