Change status from unfinished to deleted
skydev
Post by skydev » 11 Mar 2022, 05:21
Hello guys,
just want to confirm, with order/cleanup/unfinished crone can we extend and make sure it just change the status to deleted instead of permanently deleting the order
will it make any bigger difference ?
Re: Change status from unfinished to deleted
Post by aimeos » 11 Mar 2022, 07:49
No, that doesn't have any other consequences but if you want to keep the orders, just don't add "order/cleanup/unfinished" to the list of tasks in the cronjobs. The order status "unfinished" and "deleted" both behave the same.
skydev
Post by skydev » 11 Mar 2022, 09:53
No ,
Actually unfinished order cron managee stock/and voucher so we need to execute that just don't want to delete them permanently
Post by aimeos » 11 Mar 2022, 10:00
That's true, the reserved stocks are released.
You can change the status from "unfinished" to "deleted" without problems. If you can create a PR which makes that configurable, we are happy to merge it into the core :-)
