After payment (redirect to the payment page), the cart is not cleared
rud99
Post by rud99 » 21 Mar 2022, 10:44
Hello!
After payment (redirect to the payment page), the cart is not cleared.
The order is created in the system, but the basket is not cleared.
This is a part of my method "process" in my provider:
        if (isset($response->status) && $response->status === CheckoutStatus::Created) {
            $order->setPaymentStatus(\Aimeos\MShop\Order\Item\Base::PAY_PENDING);
            $this->saveOrder($order);
            if (isset($response->links)) {
                $link = collect($response->links)->filter(function ($item) {
                    return isset($item->rel) && $item->rel === 'approve';
                })->first();
                if (!$link || !isset($link->href)) {
                    return back();
                return new \Aimeos\MShop\Common\Helper\Form\Standard($link->href, 'GET');
What could be the problem? Thanks!
Re: After payment (redirect to the payment page), the cart is not cleared
Post by aimeos » 21 Mar 2022, 10:49
The basket is cleared using this code:
https://github.com/aimeos/ai-client-htm ... #L333-L337
If you have a custom implementation, you need to use it to clear the basket afterwards.
rud99
Post by rud99 » 22 Mar 2022, 11:37
Thanks, aimeos!
The issue was resolved like this:
After payment, the bank gateway should redirect the customer to the successful checkout page(url). I didn't have this page(url).
I provided the payment gateway this address (https://mysuperpuperaimeostestshop/shop ... y_pay_type) to go after successful payment.
Now the basket is cleared after payment.
