discount flags
createanet
discount flags
Post by createanet » 22 Mar 2022, 18:31
we seem to have discount flags appearing on product when the there is a rebate applied, is there a way to disable the flag so its not visible, but we still want the rebate to be applied
Re: discount flags
Post by aimeos » 24 Mar 2022, 09:20
You can change the common/summary/detail-standard.php template from the ai-client-html extension in your own extension and skip displaying the ordered rebate product in the basket which as the flag.
