How to implement a new module in the admin panel, using laravel instead of following Aimeos core package.
cojad
Post by cojad » 23 Mar 2022, 05:03
I wanted to add a new feature in Aimeos admin panel but I want to use the laravel for creating it instead of using Aimeos core classes.
Re: How to implement a new module in the admin panel, using laravel instead of following Aimeos core package.
Post by aimeos » 24 Mar 2022, 09:21
You need to implement a JQAdm class as skeleton to fit into the admin backend but you can use Laravel means in the implementation of the methods instead the Aimeos core objects.
