How to remove default tax value 20%?
GoogleUser
Post by GoogleUser » 18 May 2015, 09:42
Thanks for coding this extension,
independently which tax value i have set up in my products, there is always an additional line in the cart "Inkl. 20.00% MwSt. "
How can i remove this line?
regards, Oliver.
Re: How to remove default tax value 20%?
Post by aimeos » 18 May 2015, 09:51
Hi Oliver
GoogleUser wrote: independently which tax value i have set up in my products, there is always an additional line in the cart "Inkl. 20.00% MwSt. "
If all your products use a different tax rate, please have a look at the tax rate of the delivery option too. This is most likely the cause for the additional line.
GoogleUser
Post by GoogleUser » 22 May 2015, 12:20
That's it. Thank you.
MuazAliHuddin
Post by MuazAliHuddin » 30 Aug 2015, 19:55
Hi, i just install the package , and i want to know how to modify the tax algorithm from calculate base on price to base on new text field ( for example profit) .
How?
thank you
Post by aimeos » 31 Aug 2015, 08:56
MuazAliHuddin wrote:Hi, i just install the package , and i want to know how to modify the tax algorithm from calculate base on price to base on new text field ( for example profit) .
Can you explain this a bit more? Maybe with an example?
