Disable supplier (or disable supplier products
viptapis
Post by viptapis » 11 Apr 2022, 10:01
Hello Dear,
i tried to make the supplier "Disable" -> https://tinyurl.com/yb3toz8h
but still the Supplier products are enable on the Front.
also i tried to Disable supplier products one by one -/ from supplier page -> https://tinyurl.com/yc59ygzh
also in front its not disable.
*Note: if i disable the products from product page , its working.
so would you advice if disabling "supplier" or disable product from "supplier" page is not to disable them from front, then for that reason that function.
Regards
Vip
Re: Disable supplier (or disable supplier products
Post by aimeos » 12 Apr 2022, 11:09
Suppliers only have a weak relation to products and they are used to display additional data at products. If you disable suppliers or the supplier<->product relation, only the supplier data on the product detail page isn't shown any more. The only way to disable products of suppliers is to disable the products itself.
