How to fetch Product Related Reviews on Product Detail Page
kartikbhat
Post by kartikbhat » 12 Apr 2022, 10:52
I need to display reviews added to a particular product;
there I need pagination as well to display limited number of review on a page load;
Suggest me a possible way to achieve this
TIA :)
Re: How to fetch Product Related Reviews on Product Detail Page
Post by aimeos » 14 Apr 2022, 06:21
In Aimeos, we use the JSON REST API to fetch reviews dynamically:
https://aimeos.org/docs/latest/frontend ... i/reviews/
You can see the code here:
https://github.com/aimeos/ai-client-htm ... js#L27-L96
