how can I extend "JqadmController.php" controller
ahmed31916
Post by ahmed31916 » 15 Apr 2022, 06:22
how can I extend "aimeos-laravel\src\Aimeos\Shop\Controller\JqadmController.php" controller?
Re: how can I extend "JqadmController.php" controller
Post by aimeos » 16 Apr 2022, 08:08
Don't know if Laravel offers a way to overwrite controller actions from packages.
You may create a new controller, extend from JQAdmController, overwrite what you need and change the routes to your new controller. To disable the package routes for the JQAdmController, you need to set this in your ./config/shop.php (https://github.com/aimeos/aimeos-larave ... op.php#L15):
'routes' => [
    // other routes
    'jqadm' => false,
    // other routes
Then, add this routes in your ./routes/web.php with your new controller:
https://github.com/aimeos/aimeos-larave ... hp#L18-L60
