S3 bucket setting
IvanIgniter
S3 bucket setting
Post by IvanIgniter » 25 Apr 2022, 11:22
I am using laravel 6.x, PHP 7.4, Docker desktop/Ubuntu and the Aimeos 2021 (aimeos-laravel: 2021.10.4 / aimeos-core: 2021.10.13)
I have read the settings provided in https://aimeos.org/docs/2021.x/laravel/ ... atic-files
and successfully installed https://github.com/aimeos/ai-filesystem and this is my settings.
s3 shop settings.jpg (71.07 KiB) Viewed 5204 times
Kindly help because I noticed after successfully saving product image without any error I did not find the image in my s3 bucket and I also noticed that the product images are not stored in public/aimoes folder anymore. Please guide what did I miss in my configuration. Thank you.
Re: S3 bucket setting
Post by aimeos » 26 Apr 2022, 07:53
Hard to say, especially because you've gotten no error when saving products with images. Maybe the image is stored in S3 but not where you expect it to be.
IvanIgniter
Post by IvanIgniter » 27 Apr 2022, 10:43
Thank you for the respond. We found out that the S3 bucket provided was not set to be publicly accessable via url. Now it is working. Can I followup another question how to set config/shop.php resource to use the local if .env.APP_ENV=development to use
'resource' => []
and use the
'resource' => [
'fs' => [
'adapter' => 'FlyAwsS3',
'credentials' => [
'key' => env('AWS_ACCESS_KEY_ID'),
'secret' => env('AWS_SECRET_ACCESS_KEY'),
'region' => env('AWS_DEFAULT_REGION'),
'version' => 'latest',
'bucket' => env('AWS_BUCKET_SHOPPING'),
'baseurl' => env('AWS_URL_SHOPPING'),
if .env.APP_ENV != development?
Post by aimeos » 28 Apr 2022, 05:42
You can use:
'resource' => [
	'fs' => [
		'adapter' => env('APP_ENV') == 'development' ? 'Standard' : 'FlyAwsS3',
		'credentials' => [
		'baseurl' => env('APP_ENV') == 'development' ? env( 'ASSET_URL' ) . '/aimeos' : env('AWS_URL_SHOPPING'),
		'basedir' => public_path( 'aimeos' ),
		'tempdir' => storage_path( 'tmp' ),
IvanIgniter
Post by IvanIgniter » 28 Apr 2022, 06:41
I will try.. Thank you
