Filter by attribute_name
santfather
Post by santfather » 25 Apr 2022, 14:55
Laravel version: 8.80
Aimeos version: 2021.10
PHP version: 8.0.8
The product contains more than 10 attributes. All of these attributes are visible in the Catalog filter. For work, I need only one - a brand. How can I display only one attribute that I need in the filter?
p.s. transferring attributes to hidden ones is not suitable.
thanks in advance for your reply
Re: Filter by attribute_name
Post by aimeos » 26 Apr 2022, 13:31
Use this configuration and add the code of your brand attribute type:
https://aimeos.org/docs/2021.x/config/c ... ter/#types
Then, only that attribute type will be displayed in the catalog attribute filter.
santfather
Post by santfather » 26 Apr 2022, 13:51
Thank you for your help.
santfather
Post by santfather » 16 May 2022, 13:30
good afternoon. with these settings shop.php everything works fine on the local machine. when transferring to AWS, the online store version behaves strangely. the "colour" and "size" attributes work together, when adding "brands_name" attributes, the filter outputs only it. if you remove "brands_name", the filter outputs "colour" and "size". settings shop.php the same.
tell me what could be the problem? all attributes are created, product cards contain them in the characteristic tabs. I repeat that it works correctly on the local machine. also tested by colleagues on their local machines
Post by aimeos » 17 May 2022, 14:44
Strange behavior but we have no clue why it behaves differently on AWS.
