Colors on the category page
karpati
Post by karpati » 02 May 2022, 15:06
Hello Aimeos!
What solution do you suggest if I want to display the colors (icons) of the product on the category page (Laravel)?
Is there a simple solution?
Thank you very much!
these colors:
Re: Colors on the category page
Post by aimeos » 03 May 2022, 15:48
Add this to the ./config/shop.php file in your Laravel application:
'client' => [
	'html' => [
		'catalog' => [
			'lists' => [
				'domains' => ['attribute', 'media', 'price', 'product', 'text']
This fetches the attributes of the variant products too and you can add them in your template.
See also: https://aimeos.org/docs/latest/config/c ... s/#domains
If you enable this setting and switch to the alternative list view, you will see what you want out of the box:
https://aimeos.org/docs/latest/config/c ... basket-add
karpati
Post by karpati » 13 Jun 2022, 19:03
Hi!
Thanks for the help.
Unfortunately, I can't extract attributes from $productItem.
It does not work:
$productItem->getRefItems( 'attribute', null, 'variant' );
Can you help me?
Post by aimeos » 14 Jun 2022, 19:27
The variant attributes are attached to the variant articles, not to the selection product itself:
foreach( $productItem->getRefItems( 'product', 'default', 'default' ) as $articleItem )
	foreach( $articleItem->getRefItems( 'attribute', 'color', 'variant' ) as $attrItem ) {
		echo $attrItem->getRefItems( 'media', 'icon' )->getPreview()->first();
