Locale object not available after change routes
krzysiekp
Post by krzysiekp » 05 May 2022, 17:12
I have error "Locale object not available " when I change my routes in config/shop.php.
New entry is:
'routes' => [
'admin' => ['domain' => '{site}', 'prefix' => 'admin', 'middleware' => ['web']],
'jqadm' => ['domain' => '{site}', 'prefix' => 'admin/jqadm', 'middleware' => ['web', 'auth']],
'jsonadm' => ['domain' => '{site}', 'prefix' => 'admin/jsonadm', 'middleware' => ['web', 'auth']],
'jsonapi' => ['domain' => '{site}', 'prefix' => 'jsonapi', 'middleware' => ['web', 'api']],
'account' => ['domain' => '{site}', 'prefix' => 'profile', 'middleware' => ['web', 'auth']],
'default' => ['domain' => '{site}', 'prefix' => 'shop', 'middleware' => ['web']],
'update' => ['domain' => '{site}'],
Error occured in:
\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Context\Item\Standard.php:425
krzysiekp
Re: Locale object not available after change routes
Post by krzysiekp » 05 May 2022, 22:17
I create custom page and try using Aimeos context object in my custom controller and I receive this error. And I change my site code from "default" to "test.localhost" Bellow line causes error:
app('aimeos.context')->get()
Post by aimeos » 06 May 2022, 05:10
The site code ("default" by default) must be changed to the domain in the URL (e.g. "test.localhost"). Furthermore, you have to adapt this setting in your ./config/shop.php to that domain too:
https://github.com/aimeos/aimeos-larave ... p.php#L123
krzysiekp
Post by krzysiekp » 06 May 2022, 06:10
But I have two sites. First site has site code = test.localhost and second site has site code = test2.localhost.
Each domain has this error.
Post by aimeos » 06 May 2022, 06:13
When using your custom controller, you also have a custom route, don't you?
In that case, make sure that the domain is also used as "{site}" parameter there.
