Change Billing Address class
krzysiekp
Post by krzysiekp » 11 May 2022, 08:39
I want overwrite
\vendor\aimeos\ai-client-html\client\html\src\Client\Html\Checkout\Standard\Address\Billing\Standard.php
How to do ? Do I need to write a decorator ?
Or maybe just copy this class to
\packages\new-ext\client\html\src\Client\Html\Checkout\Standard\Address\Billing\Billing.php
and change its name and file name to
Billing.php
and then I will be able to change it ?
And how to assign such a class to a specific shop later ?
Re: Change Billing Address class
Post by aimeos » 12 May 2022, 11:16
Using a decorator is preferred if you want to add or modify data assigned to the view.
Overwriting the class is only necessary if you need to change the implementation of protected methods and then you give your new class another name (not "Billing" but e.g. "Myproject") and configure the new class name.
