NumberFormatter function not found
IvanIgniter
Post by IvanIgniter » 11 May 2022, 08:48
I am using laravel 6.x, PHP 7.4, Docker desktop/Ubuntu and the Aimeos 2021 (aimeos-laravel: 2021.10.4 / aimeos-core: 2021.10.13)
I always have this error in error logs every minute. I can't trace in our code that is calling it. Any idea why this part is always causing error?
staging.ERROR: Class 'NumberFormatter' not found {"exception":"[object] (Symfony\\Component\\Debug\\Exception\\FatalThrowableError(code: 0): Class 'NumberFormatter' not found at /var/www/backend/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Helper/Number/Locale.php:42)
NumberFormatter error-6.jpg (236.69 KiB) Viewed 2854 times
Re: NumberFormatter function not found
Post by aimeos » 12 May 2022, 11:17
NumberFormatter is a class from the PHP Intl extension which seems to be missing at your server.
