Themes and @include in blade template
krzysiekp
Post by krzysiekp » 11 May 2022, 19:38
In packages\new-theme\client\html\templates\checkout\standard\summary-body-standard.blade.php
I have below code:
 @include('common/summary/detail-standard',[
                        'summaryBasket' => $standardBasket,
                        'summaryTaxRates' => $summaryTaxRates ?? [],
                        'summaryNamedTaxes' => $summaryNamedTaxes ?? [],
                        'summaryCostsPayment' => $summaryCostsPayment ?? 0,
                        'summaryCostsDelivery' => $summaryCostsDelivery ?? 0,
                        'summaryShowDownloadAttributes' => $summaryShowDownloadAttributes ?? [],
This code causes the error:
View [common.summary.detail-standard] not found. (View: C:\xampp\htdocs\giftcard\vendor\aimeos-themes\new-theme-sk\client\html\templates\checkout\standard\summary-body-standard.blade.php)
I try use
@include('new-theme::common/summary/detail-standard' ....
but still not working
Re: Themes and @include in blade template
Post by aimeos » 13 May 2022, 06:26
Laravel uses dots instead of slashes for separating directories, e.g. "common.summary.detail-standard" (for whatever reason):
https://laravel.com/docs/9.x/blade#including-subviews
Furthermore, it may load Blade views only from the standard Laravel view directories like "resources/views".
krzysiekp
Post by krzysiekp » 13 May 2022, 06:59
Do you have somewhere converted all Aimeos template (ai-client-html\client\html\templates) to Laravel Blade ?
Post by aimeos » 13 May 2022, 07:02
No. We want to see how we can use the Blade template engine for the existing PHP files in the future.
