No node with id "3" found at setup
jan
Post by jan » 17 May 2022, 10:58
command
throws a Aimeos\MW\Tree\Exception with message
No node with ID "3" found
at vendor/aimeos/aimeos-core/src/MW/Tree/Manager/DBNestedSet.php:704
Command output before the exception:
Creating locale schema
Add locale data for languages and currencies
Adding data for MShop locale languages
Adding data for MShop locale currencies
Creating log schema
Adding data for MShop locale domain
Adding locale data if not yet present
Setting locale to "default"
Processing catalog demo data
Fresh installation of Laravel 9 with livewire/jetstream
aimeos/aimeos-laravel: 2022.04
php 8.0.12
mysql 8.0.27
Anyone else ran into this?
Re: No node with id "3" found at setup
Post by aimeos » 17 May 2022, 12:12
If you run the database migrations a second time including the demo data setup, this fails in the current version. The workaround is to delete the demo categories from the mshop_catalog table before executing the command or skip the --options parameter.
