Using variables in payment email
promptnet
Post by promptnet » 23 May 2022, 12:12
is it correct to use client.html.email.emailIntro and client.html.email.message in the scheduler TS config to change the payment email texts?
Is it possible to use variables in this texts? How can that be done?
I'd like to use the order number and the current date.
Re: Using variables in payment email
Post by aimeos » 24 May 2022, 17:11
Which Aimeos version do you use?
promptnet
Post by promptnet » 25 May 2022, 14:35
Sorry, I forgot that.
Aimeos: 20.10.11
TYPO3: 9.5.31 (will upgrade soon)
Post by aimeos » 26 May 2022, 11:12
There's no configuration to change the payment e-email intro and message but you can change them by adding your own translation. Here are the texts and there you can see also the available placeholders:
- https://github.com/aimeos/ai-client-htm ... #L509-L521
- https://github.com/aimeos/ai-client-htm ... #L535-L543
This is for the old 2020.10 version, in later versions this has been simplified and improved.
