got this error when I make order
ahmed31916
Post by ahmed31916 » 25 May 2022, 12:10
why I got this error when I make order?
Checks for available service items in basket failed
Re: got this error when I make order
Post by aimeos » 26 May 2022, 11:01
No delivery or payment option has been added to the basket and the ServicesAvailable basket plugin throws an error in that case when using the default configuration.
nowrap
Post by nowrap » 14 Aug 2023, 20:10
we are also facing this issue in a 2022.10 installation now.
Adding an item to the basket and navigating to /shop/basket shows this error - before entering any data in the checkout process.
The $problems array contains this:
array:1 [▼ // vendor/aimeos/aimeos-core/src/MShop/Plugin/Provider/Order/AddressesAvailable.php:134
  "payment" => "available.none"
The plugin AddressesAvailable uses the default configuration:
  • payment yes
  • delivery empty
Both types are tested. If i set delivery also to yes, the $problems array contains both checks - as expected:
array:2 [▼ // vendor/aimeos/aimeos-core/src/MShop/Plugin/Provider/Order/AddressesAvailable.php:134
  "delivery" => "available.none"
But this didn't happen before.
Clicking the checkout button can complete the order.
So customers might be confused about this error.
In the /shop/checkout/process view the plugin is called again.
So maybe it's called accidently on the /shop/basket view?
Post by aimeos » 16 Aug 2023, 12:51
There can be two sources for the problem:
1.) You've removed or disabled the Autofill-Plugin in the Plugin panel
2.) You've reordered the positions of the plugins in the Plugin panel and AddressAvailable isn't one of the last ones any more
nowrap
Post by nowrap » 16 Aug 2023, 17:01
Thx for pointing me in the right direction.
I think, we didn't change the default plugins:
But we added a custom BasketPlugin.
// edit
Deactivating this doesn't trigger the error message.
Reenabling makes the error message occur again.
