Site search without linking to categories
santfather
Post by santfather » 27 May 2022, 13:23
Laravel version: 8.80
Aimeos version: 2021.10
PHP version: 8.0.8
At the moment, the site search works as follows:
1. on the main page, the search results in all categories
2. on the category page - only within this category. when changing the category, the search query is not reset, but continues to search in the new category.
The question is how to set up a search for the entire site / all categories, regardless of being on the site?
Re: Site search without linking to categories
Post by aimeos » 29 May 2022, 07:13
There's a config option to change that behavior:
https://aimeos.org/docs/2022.x/config/c ... e-search_1
santfather
Post by santfather » 30 May 2022, 10:34
adding this line did not give a result. the search works only by category. the product located in the DZIECKO category by search will be visible only from the main page (where the search works for all categories), or in the DZIECKO category itself. in other categories, this product will not be found, because the search in them is limited only to this category.
how to set up a search so that it searches for products in all categories, and not in the one where you are now?
how can I change the limit on the number of pagination pages and the number of products found?
