Can super admin hide some categories for vendors
ahmed31916
Post by ahmed31916 » 02 Jun 2022, 13:05
Can I hide some categories and show others from the merchant admin interface?
Re: Can super admin hide some categories for vendors
Post by aimeos » 03 Jun 2022, 18:47
In the admin backend only if you customize the code. If you write your own code, you have full control over the displayed categories.
ahmed31916
Post by ahmed31916 » 04 Jun 2022, 12:31
May I will need to add new column in catalog table to hide or show cat, right?
Post by aimeos » 06 Jun 2022, 06:39
You can use the catalog.status property (mshop_catalog.status column) and it's values to hide categories.
ahmed31916
Post by ahmed31916 » 08 Jun 2022, 03:32
How to filter by catalog status (after get children)?
\Aimeos\MShop::create( $context, 'catalog' )->getTree()->getChildren()
Post by aimeos » 10 Jun 2022, 07:01
	->getTree()
	->getChildren()
	->filter( function( $item ) {
		return $item->getStatus() > 0;
