Overwrite pdf file for order confirmation
billy678
Post by billy678 » 02 Jun 2022, 16:10
I tried to overwrite the file which creates the pdf for the order confirmation.
There is an aimeos_extend extension and the file which creates it is the pdf.php in job package.
So I copied it to path "/aimeos_extend/Resources/Private/Extensions/aimeos_extend/templates/order/email/payment/pdf.php" - nothing happend.
Can you tell me what my mistake is?
Thank you & best regards
________
PHP 7.4
aimeos-typo3: 22.4.3
aimeos-core: 2022.04.7
Re: Overwrite pdf file for order confirmation
Post by aimeos » 03 Jun 2022, 05:20
That's correct. Did you activate your aimeos_extend extension in the ExtensionManager?
billy678
Post by billy678 » 03 Jun 2022, 09:31
Yes sure. We already did a lot of customizations.
Post by aimeos » 03 Jun 2022, 19:12
The configured template directories in the generated extensions are:
	'template' => [
		'admin/jqadm/templates' => [
			'templates/admin/jqadm',
		'admin/jsonadm/templates' => [
			'templates/admin/jsonadm',
		'client/jsonapi/templates' => [
			'templates/client/jsonapi',
		'client/html/templates' => [
			'templates/client/html',
		'controller/jobs/templates' => [
			'templates/controller/jobs',
Therefore, copy the template to
/aimeos_extend/Resources/Private/Extensions/aimeos_extend/templates/controller/jobs/order/email/payment/pdf.php
billy678
Post by billy678 » 07 Jun 2022, 11:31
That works! Thank you.
