get product attribute in the order plugin
ahmed31916
Post by ahmed31916 » 08 Jun 2022, 11:18
For this plugin code, (when I use addProduct event), how can I get the attribute of the requested product?
class Example
    extends \Aimeos\MShop\Plugin\Provider\Decorator\Base
    implements \Aimeos\MShop\Plugin\Provider\Decorator\Iface
    public function update( \Aimeos\MW\Observer\Publisher\Iface $order, $action, $value = null )
	dd($order->getProducts());
        return true;
Re: get product attribute in the order plugin
Post by aimeos » 10 Jun 2022, 07:36
Depending on the events your plugin is listening for, the data/object is passed in the $value parameter:
if( $value ) {
	$attrItems = $value->getAttributeItems();
Check the interface for available methods:
https://github.com/aimeos/aimeos-core/b ... #L401-L425
