Frontend view: missing icons, not usable
heural
Post by heural » 10 Jun 2022, 11:58
please show the attached image
Win10, PHP7.4, Aimeos-Extension 22.4.3
Thanks a lot!
Re: Frontend view: missing icons, not usable
Post by aimeos » 10 Jun 2022, 12:18
Open the browser console and check for errors
heural
Post by heural » 13 Jun 2022, 06:26
There are no JS errors, 2 network errors:
http://localhost/uploads/tx_aimeos/https://aimeos.org/media/default/product_04_A-low.jpg
http://localhost/uploads/tx_aimeos/https://aimeos.org/media/default/product_05_A-low.jpg
The installation is in a subdir:
http://localhost/typo3/aimeos/public
Thanks a lot!
Post by aimeos » 13 Jun 2022, 07:15
heural wrote: 13 Jun 2022, 06:26 The installation is in a subdir:
This usually causes problems and the ./public/ directory must be the document root ("/").
heural
Post by heural » 14 Jun 2022, 06:16
Ok, i´ve created a vhost aimeos.local but same effect.
Maybe i should try a fresh installation?
Thanks a lot!
Post by aimeos » 14 Jun 2022, 07:21
Did you clear the caches?
heural
Post by heural » 14 Jun 2022, 07:29
Yes, i did
Thanks a lot!
Post by aimeos » 14 Jun 2022, 07:40
This is strange because the image URLs shouldn't be generated this way:
https://github.com/aimeos/aimeos-base/b ... hp#L53-L55
Another thing is that the icons are missing which looks like the FontAwesome URL is not included.
heural
Post by heural » 14 Jun 2022, 11:17
I installed new with distribution from this manual https://github.com/aimeos/aimeos-typo3-dist#composer and it works ;-)
However, thx you for your fast answers!
Thanks a lot!
heural
Post by heural » 21 Jun 2022, 08:24
I have installed another instance of aimeos, with the Typo3-Extensions from TER (Framework "aimeos 22.4.3" and Distribution "aimeos_dist 22.4.1") and the bootstrap-icons are missing again.
As I described above, that worked with my previous installation with composer (https://github.com/aimeos/aimeos-typo3#installation), so compared the typoscript in template beetween the installations:
From TER-Install, there are missing lines:
4: page.includeCSSLibs.aimeos = EXT:aimeos/Resources/Public/Themes/default/aimeos.css
5: page.includeCSSLibs.aimeos-typo3 = EXT:aimeos/Resources/Public/Themes/default/typo3.css
6: page.includeJSFooterlibs.aimeos = EXT:aimeos/Resources/Public/Themes/default/aimeos.js
Thanks a lot!
