Error cron on once a day jobs
Arth
Post by Arth » 19 Jun 2022, 05:15
got an error message on cron daily jobs. What may be the cause?
Re: Error cron on once a day jobs
Post by aimeos » 20 Jun 2022, 07:51
You have several Aimeos sites in your database and execute the index/rebuild job for all sites. That is done in several parallel processes and can cause transaction problems. Add the site code you want to execute the jobs for at the end of the cronjob command, e.g.:
0 1 * * * php /path/to/artisan aimeos:jobs "index/rebuild" default
