Cacheable Detail
billy678
Cacheable Detail
Post by billy678 » 21 Jun 2022, 14:48
Non-cacheable pages are not indexed by "Indexed Search".
Your detail plugin is set to non-cachable. If I set the detail action from the plugin to non-cachable it shows the same detail for every product.
Do you have any workaround for this issue?
Re: Cacheable Detail
Post by aimeos » 24 Jun 2022, 09:48
Unfortunately, not. Aimeos maintains it own cache based on the configuration and the parameters to avoid caching the same product several times.
