Custom provider labels
DaleWastell
Post by DaleWastell » 28 Jun 2022, 09:35
Hello Aimeos,
Thank you for this awesome package. We in Mayapur are busy implementing it for our international multi million dollar donation and volinteer based community project: Temple of Vedic Planetarium (TOVP) and have some very specific payment gateway requirements which appear to fall outside the scope of Omnipay.
I am using the latest versions of Aimeos and PHP to date.
Firstly, a small documentation change:
in the sample code: new \Aimeos\MW\Criteria\Attribute\Standard
needs to change to: new \Aimeos\Base\Criteria\Attribute\Standard
It would also be useful to know that the new provider needs to be placed in the /MShop/Service/Provider/Payment folder.
I copied the structure of DirectDebit.php for some reference but am having an issue in the label (snips below). What am I missing?
I would also like to know how to add in a country dropbox.
Code:
<?php
namespace Aimeos\MShop\Service\Provider\Payment;
class MayapurPaymentPortal
extends \Aimeos\MShop\Service\Provider\Payment\Base
implements \Aimeos\MShop\Service\Provider\Payment\Iface
private $feConfig = array(
'MayapurPaymentPortal.first_name' => array(
'code' => 'mayapurpaymentportal.first_name',
'internalcode' => 'MPPFirstName',
'label' => 'First Name',
'type' => 'string',
'internaltype' => 'string',
'default' => '',
'required' => true
'MayapurPaymentPortal.last_name' => array(
'code' => 'MayapurPaymentPortal.last_name',
'internalcode' => 'MPPLastName',
'label' => 'Last Name',
'type' => 'string',
'default' => '',
'required' => true
public function getConfigFE( \Aimeos\MShop\Order\Item\Base\Iface $basket ) : array
$feconfig = $this->feConfig;
return $this->getConfigItems( $feconfig );
public function setConfigFE( \Aimeos\MShop\Order\Item\Base\Service\Iface $orderServiceItem,
array $attributes ) : \Aimeos\MShop\Order\Item\Base\Service\Iface
$orderServiceItem = $this->setAttributes( $orderServiceItem, $attributes, 'payment' );
return $orderServiceItem;
public function checkConfigFE( array $attributes ) : array
return $this->checkConfig( $this->feConfig, $attributes );
public function process(\Aimeos\MShop\Order\Item\Iface $order,
array $params = []): ?\Aimeos\MShop\Common\Helper\Form\Iface
$basket = $this->getOrderBase( $order->getBaseId() );
$total = $basket->getPrice()->getValue() + $basket->getPrice()->getCosts();
// define the payment information that should be sent to the external payment gateway
$list = [
'MayapurPaymentPortal.pancode' => new \Aimeos\Base\Criteria\Attribute\Standard( [//local / international
'label' => 'Pan Code',
'code' => 'MayapurPaymentPortal.pancode',
'type' => 'string',
'default' => "",
'public' => true,
$gatewayUrl = 'http://127.0.0.1:8000/PGSim.php';
return new \Aimeos\MShop\Common\Helper\Form\Standard( $gatewayUrl, 'POST', $list );
Thank you in advance
Re: Custom provider labels
Post by aimeos » 28 Jun 2022, 10:36
DaleWastell wrote: 28 Jun 2022, 09:35 Firstly, a small documentation change:
Thanks for the hints. This has been changed in the master branch and will be released soon:
https://aimeos.org/docs/master/provider ... e/payment/
DaleWastell wrote: 28 Jun 2022, 09:35 I would also like to know how to add in a country dropbox.
How to add selections for custom attributes is explained here:
https://aimeos.org/docs/latest/provider ... figuration
Use "select" or "list" as type and add the list of countries to the "default" property.
