Request for new feature
thisisbintang
Post by thisisbintang » 03 Jul 2022, 10:33
Good evening, I want to change customer.address.position in the patch request aimeos jsonapi but it doesn't work.
I did a direct search of ai-client-jsonapi and aimeos/core source code to learn how the process of patch request works. All I get is confusion. I ask for your help to add a feature to change customer.address.position in the patch request. Thank you and consider.
Screenshot from 2022-07-03 17-32-51.png (42.62 KiB) Viewed 3121 times
thisisbintang
Re: Request for new feature
and this is the response to the request
Screenshot from 2022-07-03 17-33-03.png (7 KiB) Viewed 3120 times
thisisbintang
Post by thisisbintang » 04 Jul 2022, 03:34
Aimeos version: 2022.04
PHP: 8.1.7
Linux system: Ubuntu 21.04
Post by aimeos » 04 Jul 2022, 13:58
The PATCH method for the basket/address resource is brand new and will be available in 2022.07+
Furthermore, you won't be able to change a single field like "order.base.address.position" because Aimeos supports adding several addresses. Instead, you have to pass the complete billing or delivery address(es) to the JSON API and it will remove the existing ones first and add the new ones afterwards - just like the new PATCH method for basket/service.
