Creating a copy of a product based on a previous copy is not saved
РоманАндрейчук
Post by РоманАндрейчук » 06 Jul 2022, 07:31
Environment
Version (e.g. 2021.10)
Integration (Laravel)
System (Linux, Mac)
Hello!
I have a problem with creating new products. Creating a copy of a product based on a previous copy is not saved.
The logs show the following error:
Couldn't copy file from "1.d/files/4/9/49381151_1-d-files-1-8-1820bf6f_1-d-files-3-7-37efe3a7_1-d-files-2-b-2b6bfefb_1-d-files-c-0-c00e8e37_1-d-files-1-5-15233870_1-d-files-c-b-cb126af9_1-d-files-e-d-ed0388bf_1-d-files-c-7-c75e5b55_1-d-files-9-9-9922243e_2022-07-04_20-36-01.jpg" to "1.d/files/4/b/4ba47f99_1-d-files-4-9-49381151_1-d-files-1-8-1820bf6f_1-d-files-3-7-37efe3a7_1-d-files-2-b-2b6bfefb_1-d-files-c-0-c00e8e37_1-d-files-1-5-15233870_1-d-files-c-b-cb126af9_1-d-files-e-d-ed0388bf_1-d-files-c-7-c75e5b55_1-d-files-9-9-9922243e_2022-07-04_20-36-01.jpg"
It looks like the problem is with the long filename. How to change the pattern of the new image filename when copying a product?
Re: Creating a copy of a product based on a previous copy is not saved
Post by aimeos » 06 Jul 2022, 08:23
We've changed the code and remove the first parts now before copying the file. The change is available if you execute:
composer req aimeos/aimeos-core:2021.10.x-dev
Can you test and confirm that it works now?
Post by aimeos » 14 Jul 2022, 10:41
The new code does NOT remove existing prefixes added in previous copy actions. Please test with a product that doesn't already have long image URLs and check that copying that product recursively does only add nine characters of a hash and the total length of the URL doesn't grow after the second copy action any more.
РоманАндрейчук
Post by РоманАндрейчук » 22 Aug 2022, 09:18
Hello.
This example was made based on a new product in a dev release
Post by aimeos » 22 Aug 2022, 12:01
Unable to reproduce the issue when using aimeos/ai-admin-jqadm 2021.10.18+ or dev-master
