add more than one language to the attribute type
ahmed31916
Post by ahmed31916 » 06 Jul 2022, 11:12
Is there a possibility to add more than one language to the attribute type? for example: Color
Re: add more than one language to the attribute type
Post by aimeos » 07 Jul 2022, 11:03
Yes, you can add translation for the attribute type in your ./config/shop.php in the "i18n" section:
https://aimeos.org/docs/latest/laravel/ ... anslations
In the HTML client templates, the codes are translated here:
https://github.com/aimeos/ai-client-htm ... y.php#L381
An example for a translation would be:
'i18n' => [
    'en' => [
        'client/code' => [
            'color' => ['Colour'],
    'de' => [
        'client/code' => [
            'color' => ['Farbe'],
