How to install Postfinance
jiguh
Post by jiguh » 07 Jul 2022, 06:48
aimeos-laravel: 2022.04
Laravel Framework 9.19.0
Composer version 2.3.7
PHP 8.1.3
Laragon Win10
Someone can guide me on how to implement a Postfinance payment gateway for Laravel?
Already tried https://aimeos.org/docs/User_Manual/Adm ... ostfinance but got errors:
Problem 1
- Root composer.json requires bummzack/omnipay-postfinance ~0.1 -> satisfiable by bummzack/omnipay-postfinance[0.1.0, 0.1.1, 0.1.2].
- Conclusion: don't install symfony/http-foundation v6.1.2 (conflict analysis result)
- Conclusion: don't install laravel/framework v9.18.0 (conflict analysis result)
- Conclusion: don't install laravel/framework v9.19.0 (conflict analysis result)
- Root composer.json requires aimeos/aimeos-laravel ~2022.04 -> satisfiable by aimeos/aimeos-laravel[2022.04.1, ..., 2022.04.x-dev].
- aimeos/aimeos-laravel[2022.04.1, ..., 2022.04.x-dev] require laravel/framework ^9.0 -> satisfiable by laravel/framework[v9.2.0, ..., 9.x-dev].
- laravel/framework[v9.2.0, ..., 9.x-dev] require symfony/http-foundation ^6.0 -> satisfiable by symfony/http-foundation[v6.0.0-BETA1, ..., 6.2.x-dev].
- Conclusion: don't install symfony/http-foundation v6.0.10 (conflict analysis result)
Composer.json:
"name": "aimeos/aimeos",
"description": "Aimeos ecommerce and shop system",
"keywords": ["aimeos", "ecommerce", "shop", "laravel", "distribution"],
"license": "MIT",
"type": "project",
"repositories": [{
"type": "composer",
"url": "https://packages.aimeos.org/aimeoscom"
"type": "path",
"url": "packages/*"
"require": {
"php": "^8.0.10",
"composer-runtime-api": "^2.1",
"aimeos/aimeos-laravel": "~2022.04",
"aimeos/ai-cms-grapesjs": "~2022.04",
"guzzlehttp/guzzle": "^7.2",
"laravel/breeze": "^1.9",
"laravel/framework": "^9.2",
"laravel/sanctum": "^2.14.1",
"laravel/tinker": "^2.7"
"require-dev": {
"fakerphp/faker": "^1.9.1",
"laravel/sail": "^1.0.1",
"mockery/mockery": "^1.4.4",
"nunomaduro/collision": "^6.1",
"phpunit/phpunit": "^9.5.10",
"spatie/laravel-ignition": "^1.0"
"autoload": {
"psr-4": {
"App\\": "app/",
"Database\\Factories\\": "database/factories/",
"Database\\Seeders\\": "database/seeders/"
"autoload-dev": {
"psr-4": {
"Tests\\": "tests/"
"scripts": {
"post-autoload-dump": [
"Illuminate\\Foundation\\ComposerScripts::postAutoloadDump",
"@php artisan package:discover --ansi"
"@php -r \"file_exists('.env') || copy('.env.example', '.env');\""
"post-create-project-cmd": [
"@php artisan key:generate --ansi",
"App\\Composer::configure",
"@php artisan migrate",
"App\\Composer::setup",
"App\\Composer::account",
"App\\Composer::success"
"post-update-cmd": [
"@php artisan vendor:publish --tag=laravel-assets --ansi --force",
"@php artisan vendor:publish --tag=public --ansi --force"
"extra": {
"laravel": {
"dont-discover": []
"config": {
"optimize-autoloader": true,
"preferred-install": "dist",
"sort-packages": true
"minimum-stability": "dev",
"prefer-stable": true
Re: How to install Postfinance
Post by aimeos » 07 Jul 2022, 11:31
Guzzle 7.2+ is required in your composer.json, but the bummzack/omnipay-postfinance driver requires Guzzle 6.3.
We've created a PR to allow 7.x too but don't know when it will be merge:
https://github.com/bummzack/omnipay-postfinance/pull/11
jiguh
Post by jiguh » 08 Jul 2022, 05:35
It seems they have merged it but still some errors:
Problem 1
- Conclusion: don't install symfony/http-foundation[v6.1.2] | install omnipay/common[v2.3.3] (conflict analysis result)
- bummzack/omnipay-postfinance[0.1.0, ..., 0.1.2] require omnipay/common ~2.0 -> satisfiable by omnipay/common[v2.0.0, ..., 2.5.x-dev].
- Conclusion: don't install omnipay/common v2.3.3 (conflict analysis result)
- Conclusion: don't install omnipay/common 2.5.2 (conflict analysis result)
- Root composer.json requires laravel/framework ^9.2 -> satisfiable by laravel/framework[v9.2.0, ..., 9.x-dev].
- omnipay/common[v2.3.4, ..., v2.5.0] require symfony/http-foundation ~2.1 -> satisfiable by symfony/http-foundation[v2.1.0, ..., 2.8.x-dev].
- You can only install one version of a package, so only one of these can be installed: symfony/http-foundation[v2.1.0, ..., 2.8.x-dev, v3.0.0-BETA1, ..., 3.4.x-dev, v4.4.0-BETA1, ..., 4.4.x-dev, v5.0.0-BETA1, ..., 5.4.x-dev, v6.0.0-BETA1, ..., 6.2.x-dev].
- Conclusion: install one of symfony/http-foundation[v6.0.10, v6.1.2] (conflict analysis result)
Post by aimeos » 08 Jul 2022, 08:52
The maintainer didn't tag a new version and to get the latest code including the patch, you have to run:
composer req bummzack/omnipay-postfinance:dev-master
jiguh
Post by jiguh » 08 Jul 2022, 14:35
And lastly, what value should I put on those red fields please?
Please let me know if I should do/add something that may not have been mentioned in the following docs: https://aimeos.org/docs/User_Manual/Adm ... ostfinance
Post by aimeos » 08 Jul 2022, 14:48
You are referring to old documentation, please see here:
https://aimeos.org/docs/latest/manual/s ... ostfinance
There's inline help available if you click on the labels before the input fields or on the button with the "?" sign at the top right.
