only one job is working who is in the last position
- VirtualSpy
- Advanced
Aimeos Version 2021.10.5, PHP Version php-7.4.19-Win32-vc15-x64
i configured the two Cronjobs but only one job is working who is in the second position ....please help me to merge all jobs
'controller' =>
array(
'jobs' =>
array(
'product' =>
array(
'import' =>
array(
'csv' =>
array(
'location' => base_path('storage'),
'skip-lines' => 1,
'mapping' =>
array(
'item' =>
array(
0 => 'product.code',
1 => 'product.label',
2 => 'product.type',
3 => 'product.status',
'text' =>
array(
4 => 'text.type',
5 => 'text.content',
6 => 'text.type',
7 => 'text.content',
'media' =>
array(
8 => 'media.url',
'price' =>
array(
9 => 'price.currencyid',
10 => 'price.quantity',
11 => 'price.value',
12 => 'price.taxrate',
'attribute' =>
array(
13 => 'attribute.code',
14 => 'attribute.type',
'product' =>
array(
15 => 'product.code',
16 => 'product.lists.type',
'property' =>
array(
17 => 'product.property.value',
18 => 'product.property.type',
'catalog' =>
array(
19 => 'catalog.code',
20 => 'catalog.lists.type',
'controller' =>
array(
'jobs' =>
array(
'catalog' =>
array(
'import' =>
array(
'csv' =>
array(
'location' => base_path('storage/import'),
'skip-lines' => 1,
'mapping' =>
array(
'item' => array(
0 => 'catalog.code',
1 => 'catalog.parent',
2 => 'catalog.label',
3 => 'catalog.status',
'text' => array(
4 => 'text.type',
'media' => array(
6 => 'media.url',
'controller' =>
array(
'jobs' =>
array(
'product' =>
array(
'import' =>
array(
'csv' =>
array(
'skip-lines' => 1,
'mapping' =>
array(
'item' =>
array(
'text' =>
array(
4 => 'text.type',
6 => 'text.type',
'media' =>
array(
8 => 'media.url',
'price' =>
array(
'attribute' =>
array(
'product' =>
array(
'property' =>
array(
'catalog' =>
array(
'controller' =>
array(
'jobs' =>
array(
'catalog' =>
array(
'import' =>
array(
'csv' =>
array(
'skip-lines' => 1,
'mapping' =>
array(
'item' => array(
'text' => array(
4 => 'text.type',
'media' => array(
6 => 'media.url',
Re: only one job is working who is in the last position
You can have only one CSV import configuration in your ./config/shop.php.
One option would be to create own CSV importers extending from the existing one which use different configurations.
- VirtualSpy
- Advanced
thank you so much for your reply ......and please guide me to create own CSV importers
Here's the documentation for creating own job controllers:
https://aimeos.org/docs/latest/cronjobs ... ontroller/
You can extend your new job controller from the existing product CSV import controller:
https://github.com/aimeos/ai-controller ... andard.php
The important thing is that you use another configuration key for the mapping so you can configure two different mappings:
https://github.com/aimeos/ai-controller ... #L239-L259
- VirtualSpy
- Advanced
I have created own csv importer for category and product import but i am not getting to understand what should be different in configuration ......please help me for configuration
- VirtualSpy
- Advanced
I did this configuration with created own job controller but still facing same problem .....please help me to solve this problem
- config.png (219.14 KiB) Viewed 7223 times
- VirtualSpy
- Advanced
now my problem has solved .....i merged both configuration in one controller job configuration after making own importers
