Delete doesn't work
Delete doesn't work
Hi!
When I click on the icon to delete (in any of the tables in the administrative part), it does not delete the resource.
In the browser console you can see the following error:
TypeError: Cannot read properties of undefined (reading 'target')
at Vue.askDelete (js?locale=en:5431:25)
I am using the latest version of Laravel Aimeos (2022.07.2).
Regards,
Regards,
Re: Delete doesn't work
We can't reproduce that. Can you please post a screenshot?
Sure, I share a screenshot with you. When I click on the icon to delete, it does not work and shows that error in the console.
Regards,
Regards,
- delete errror.PNG (65.39 KiB) Viewed 8245 times
Thanks, this has been fixed in the latest release. Please run "composer up" to get the latest version.
The languages will be added again by "artisan aimeos:setup" so you should disable them instead if you don't need them.
Hello Sir,
I have run composer up, then cleared all caches and the issue persists
We need a bit help now.
Can you verify that this line is exactly the same in your ./vendor/aimeos/ai-admin-jqadm/templates/admin/jqadm/locale/language/list.php file?
https://github.com/aimeos/ai-admin-jqad ... t.php#L266
Furthermore, please add this:
Here: https://github.com/aimeos/ai-admin-jqad ... in.js#L897
Then, post the output from the browser console.
console.log(ev);Then, post the output from the browser console.
Hello Sir,
Thank you very much for your prompt response,
The line of code is different in packages/my-theme/templates/admin/jqadm/locale/language/list.php
It is as follows:
Added the console.log(ev) to vendor/aimeos/ai-admin-jqadm/js/admin.js
Attached screenshot.
Best regards,
It is as follows:
<a class="btn act-delete fa" tabindex="1" href="#"
v-on:click.prevent.stop="askDelete(`<?= $enc->js( $id ) ?>`)"
title="<?= $enc->attr( $this->translate( 'admin', 'Delete this entry' ) ) ?>"
aria-label="<?= $enc->attr( $this->translate( 'admin', 'Delete' ) ) ?>">
</a>Attached screenshot.
Best regards,
- console-admin-js.PNG (20.65 KiB) Viewed 8179 times
I added $event to the line of code:
Now when I press the delete icon the confirmation modal to delete appears, however when I click delete the page reloads and the resource I tried to delete is still there, it is not deleting.
<a
tabindex="1"
v-on:click.prevent.stop="askDelete(`<?= $enc->js( $id ) ?>`, $event)"
href="#"
</a>Now when I press the delete icon the confirmation modal to delete appears, however when I click delete the page reloads and the resource I tried to delete is still there, it is not deleting.
That's because your href value is wrong and it needs to be like in the original template:
https://github.com/aimeos/ai-admin-jqad ... t.php#L267
I started the theme by downloading the base files from the aimeos online tool.
I have modified the href anyway so that the resources can be removed.
Now it works fine!
Thank you very much for your help!
Now it works fine!
